Tractor opinions
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2016 at 6:20pm
70 HP on a gas D17 is a little hard to believe unless its had some major engine work,no way a D17 is close to my D19 gas(72HP) or even my Oliver 1650 diesel (67HP)
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2016 at 7:46pm
"When changing from a forward gear to reverse will the PTO continue running on the 190."
I'm pretty sure the answer is no.
You need a newer tractor with a "true" live pto
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2016 at 9:55pm
Originally posted by Allis dave Allis dave wrote:
I would think that round baling without a kicker on a 190 would be a pain. Starting and stopping the baler won every bale to backup?
Every roll I've ever rolled was behind a 185 or D19. You don't have to stop the baler to back up. Just use the hand clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2016 at 10:05pm
It's had some work, .125 overbore, cam grind, M&W pistons, and some other things. It's also capable of turning more rpm than stock.
The engine was in my pulling tractor. When I decided to build another engine for it, I put the engine in the tractor I use around the farm. About all I do with it is pull a wagon or rake hay.
Edited by m16ty - 24 Dec 2016 at 10:09pm
