Tractor died, won't start.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2015 at 11:42am
That's what I did.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2015 at 11:53am
oops I was slow on the typing.  Good deal.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2015 at 12:00pm
Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2015 at 12:05pm
You quite likely burnt a wire somewhere between the regulator and the battery. One thing I see here that everybody missed is Ford generators are backwards from everything else. Our A-C's with a Delco generator control the field on the GROUND side of the circuit. That's why when you ground the F terminal on a Delco, it gives maximum charge. Ford on the other hand chose to control the SUPPLY side. So when you grounded the Field to the chassis, you created a direct short to ground and something couldn't take it. My guess is the ignition switch or a splice in the harness. You've probably welded the points in the regulator too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2015 at 1:10pm
I'll take a look at it.
But like I said, I've done it before with no ill effect. I've even found it on generator testing charts; ground the field to max out generator output.
And keep in mind the switch and wiring harness are fine. I got it to run by jumpering across the resistor.
Edited by CrestonM - 25 Nov 2015 at 1:17pm
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2015 at 2:09pm
You may have a resistance somewhere else in the wiring and by shorting the resistor you compensated for that resistance. I would still check ALL wiring between the battery and the ignition switch and the resistor. Go ahead and put a new resistance in, but be prepared to check the wiring if the resistor doesn't fix the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2015 at 7:03pm
If you short the field terminal on a Ford generator or alternator to ground, you'll weld every time. If you grounded the field terminal, and didn't burn anything, you didn't have a Ford charging system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2015 at 7:06pm
Check the battery terminal at the regulator with a test light. I'm betting you find no voltage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2015 at 6:08am
It might be 'show and tell' time ! Please post a picture of the genny/regulator and the 'ballast resistor(back of left dash are) as  Brian might be onto something. This is one of those hard to 'long distance' troubleshoot problems that a picture could be worth more than 1000 words !
since I can't get my tractor into my garage I have some free time.....
Jay
This page was generated in 0.912 seconds.
