tractor chuggs when mowing |
teeitupfour
Topic: tractor chuggs when mowingPosted: 23 May 2024 at 9:58pm |
my allis chuggs when mowing after mowing 20 min then stops chugging if I disengage the blades and let sit idle but then chuggs after 20 min again ???
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3952 |
Posted: 23 May 2024 at 10:12pm |
sounds like somthing is in the tank blocking it
Unit3
Posted: 23 May 2024 at 10:16pm |
What size is your tractor? My 200 just went through the same thing. There was some debris caught in between the two fittings underneath the fuel tank on the right side. Good luck hope this helps.
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1512 |
Posted: 24 May 2024 at 7:42pm |
Well we know it's an Allis! And it chugs. Lol. Everything else is a mystery. May the best guess win!!!!
plummerscarin
Posted: 24 May 2024 at 8:07pm |
Have a 200 here. Went through similar problems. It would also run hot. Granted, it was hot outside but losing power wasn't right. I changed both fuel filters which didn't help much so I disconnected the fuel line at the inlet side of the first filter. Very little flow from the fuel tank. Blew compressed air in the line back to the tank and have had no issues since. Granted this is likely to happen again but am not going to do a proper flush at this time.
Ed (Ont)
Posted: 26 May 2024 at 8:48pm |
There are a lot of guys here that will help you but you need to give a lot more info on the tractor and problem.
AllisFreak MN
Joined: 07 Dec 2009 Location: Minnesota Points: 1590 |
Posted: 26 May 2024 at 9:25pm |
It appears they don't give a chit. Scammer maybe?
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8684 |
Posted: 27 May 2024 at 9:06am |
I don't understand the nomenclature. What does it mean to "chug". Does that mean it runs or stops running?
Codger
Posted: 27 May 2024 at 9:31am |
Probably a bad rendition and relay of the problems/symptoms. Lot of variable(s) but would need to know gas, diesel, fuel gas, etc. New poster so very well could be spam of some sort.
That's All Folks!
