Tractor brush hog hook up |
Smoke
Topic: Tractor brush hog hook upPosted: 22 Mar 2017 at 1:02pm |
I just purchased a 1963 D 17 series III tractor with after market 3PT. I also purchased a 7 foot SW842 Sidewinder brush hog. My problem is that they won't hook up. If the drive shaft is hooked up then the lower arms on the 3 pt. are to short and won't let out any. If I hook up the lower arms on the 3 pt. and leave the drive shaft unhooked then the top link adjusted up all the way is still to long and when you lift the hog only the front end of it will come up.Do I need to get a different 3 pt. hitch or is there another way around this to make it hook up so I can use it?
Leon n/c AR.
Joined: 19 Mar 2013 Location: Heber Springs A Points: 177 |
Posted: 22 Mar 2017 at 1:25pm |
Sounds like you need to shorten driveshaft, not unusual. Leon
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3200 |
Posted: 22 Mar 2017 at 2:25pm |
Probably a different top link would be what you need I have a bunch of different length
top links to fit the tractors/equipment nothing 'standard' about them. |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55282 |
Posted: 22 Mar 2017 at 6:20pm |
Since you are putting a new piece of equipment on an older tractor, hook it up with no drive shaft attached, and see if it lifts level, alt he way up. If it does, likely its the pto shaft that needs trimming.
Here's the best video, I have seen on the subject: [TUBE]http://youtu.be/0vBFJcvs5SE[/TUBE]
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 22 Mar 2017 at 8:08pm |
make sure to have a overrunning clutch on the pto shaft so it does not tear up the tractor
Dakota Dave
Posted: 22 Mar 2017 at 9:47pm |
If your three point is 14" from the end of the pto shift to the eyes on the end of the lift arms and your pto shaft bottoms out you need to take the shaft apart and trim both halves of the shaft. The top link should be adjusted so the bush hog sits slightly lower in the front than the back when in the cutting position. You'll need a shorter top link to lift the bush hog. At 8' it's a CAT 2 implement. Either use a limit chain or stop to limit the lift arm drop to the height you want to cut at. The 14" measurement is the industry standard for a Cat 1 implement. All recent production tractors should meet this measurement. When you buy a new implement on most of the time you'll have to buy the PTO shaft that fits your tractor. Used implements come with the shaft that fit the last guys tractor. When you trim the shaft make sure you take enough off so it won't bottom out bottoming out the PTO will destroy either the gear box or your tractor.
Edited by Dakota Dave - 22 Mar 2017 at 9:50pm |
TimNearFortWorth
Posted: 22 Mar 2017 at 9:50pm |
Strongly recommend downloading a manual for the cutter from their site. They will list guidelines for how much inner shaft is required to be in the outer portion for proper (safe) operation.
You need to measure it out so not binding when up but leave enough to properly handle the torque while set fully down at cutting height. Sounds like cutting the shaft to length and a different top link adjuster may be in order. I do not run mine (SQ172) engaged while fully raised as the angle raises cane on the U-joints, something to remember if you ever end up in an "angled bind" while cutting in rough terrain as you can tear up the cutter plus do major damage to the tractor internals by slamming the tractor PTO shaft forward. |
Scott B
Joined: 14 Sep 2013 Location: Kansas City Points: 1055 |
Posted: 22 Mar 2017 at 10:34pm |
A quick hitch connected to your 3 pt may solve the problem. I have the same issue with my series 1. Using a quick hitch will set the implement back 3-4 inches from the 3 pt arm connection and allow more room to connect the shaft
D17 Series 1
Allis B- 1939 Allis B- 1945 |
Bob-Maine
Joined: 11 Sep 2009 Location: Central Maine Points: 922 |
Posted: 23 Mar 2017 at 7:22am |
Smoke, One thing I learned with my bush hog on my D-14 is, a rigid top link can be a problem when you are on uneven ground. If the front of the tractor goes up, the top link goes into compression and can bend the bush hog connections. I replaced the top link with a piece of chain. No more bent arms. When the bush hog is raised, it works just like a rigid top link. When a rigid top link would go into compression because the tractor front goes up or the bush hog tail wheel goes up, the chain goes slack. Hope this helps. Bob@allisdowneast
I used to think I was indecisive, but now I'm not sure.
Smoke
Posted: 23 Mar 2017 at 8:13am |
A big thanks to all of you who have commented on my question. The comment's shared are all great advice and I have learned a bunch here. I'm sure I will be using this forum often as problems arise that I know nothing about, and I know I van count on you all to help me out. Thanks again, smoke
Dennis J OPKs
Joined: 12 Sep 2009 Location: Overland Park, Points: 582 |
Posted: 23 Mar 2017 at 8:22am |
I 2nd the use of a heavy chain to replace the top link, it gives the brush hog more ability to float on uneven ground. Someone had already done that on my unit when I acquired it.
DiyDave
Posted: 23 Mar 2017 at 6:45pm |
If you can find an old AC bush hog top link rooster comb, v bar, and chains, its the best set up for ANY bush hog, mounted on an AC snap coupler conversion...
