Tractomotive Loader TL
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Tractomotive Loader TL
    Posted: 12 Nov 2018 at 5:10am
Groove in the shaft, a little extra wear on a support bushing, all little things internally worn to allow a little extra movement and clearances.
MattLF9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2018 at 7:43pm
I'm wondering if you have a groove worn into the converter and it won't allow it to seal?
A little CQB never hurt anybody.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2018 at 6:48pm
There has got to be a problem with the torque converter, worn out or whatever.  How much work would it be to put a different one in?  Things like that just wear out over time.
Scrap Yard are almost four letter words - never to be spoken in regards to Allis Chalmers!
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2018 at 12:52pm
Solution: haul to scrap yard.
MurphyLake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MurphyLake Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2013 at 10:50pm
My TL10 has the serial #35 and the torque converter is 36.
I worked it on a farm for several years without leaks.
An auxiliary hydraulic outlet was added to the front to operate a tree spade.
The engine was upgraded to a WD45
iA Charlyn pump was added for power steering.
Some time after restoration the torque converter began to leak.
It became so constant so as to make the machine unusable .
The engine has been removed four times to get to the converter seal.
The shaft has a single ring for a seal.
The leak continues..
Looking for a solution..
Edited by MurphyLake - 16 Jul 2013 at 10:52pm
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2013 at 6:05pm
I've looked there and they only have a manual for the motor since it's a B-125. Do you have anything that will explain to me how to adjust the clutch to get the right amount of pull?
iceberg210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iceberg210 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2013 at 8:52am
JenSales Manual sales I know had one for the TL 12,
Don't know if they have one for the TL6
http://www.jensales.com/Search.html#/Search.html?search=allis+chalmers+tl6&category=F50996
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2013 at 5:25am
I have a parts book for the machine but I would like to get an owners/operators manual for it if one is available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote iceberg210 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2013 at 11:14pm
Automatic transmission fluid, note that this fluid also runs the power steering. I believe the level was standard 4 or something that they are now on standard 6 or something so any ATF will do... Also make sure to clean out the strainer on the return line, my TL 12 had that plugged which was a lot of where my issues were... If you have any other questions let me know, the old Tractomotive/AC machines are absolutely incredible especially for their time and are awfully handy to have around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2013 at 9:57am
What kind of fluid do you guys run in your transmissions (Tractomotive clutch type) on the TL-6, TL-10, TL-11 or TL-12?
