Track truck roller reseal HD6E
mahto48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahto48 Quote  Post ReplyReply Direct Link To This Post Topic: Track truck roller reseal HD6E
    Posted: 19 Mar 2018 at 5:19pm
Is there anyone that know a source for the ring seal spring assembly for resealing the trucks. Part # 047581 package # 083536
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 6:51pm
I should have some seals assembly for HD6 bottom roller am checking tomorrow and comback you
Ullrich Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ullrich Farms Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 8:02pm
Did you find replacement track roller seals for your HD6?
I'm rebuilding my Dad's HD5 and in need of track roller seals. The rubber boots at cracked and separating.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahto48 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2018 at 10:39am
Thanks for looking. I'm thinking there are two types (standard and heavy duty) Any thoughts on that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahto48 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2018 at 10:42am
I'm still looking.Confused I will keep you in mind.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2018 at 1:12pm
I check today and have some bottom roller seals
1 spring ass.048666
1 boots 048665
2 rings seal 047151
1 gasket seal 047605
 these parts are hold stock new
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2018 at 1:31pm
Minnpar shows stock of 70047581 spring assembly...  I'll put in a little plug for them as they have really helped me keep my old Allis going.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2018 at 1:44pm
The 047581 is seal for HD5 top roller and have 2 new one
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahto48 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2018 at 10:12am
Turns out I have the heavy duty rollers. The one spring ass. #048666 and the one boot ass. #048665 will fit. Do you want to part with them. Please send me a private message.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahto48 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2018 at 10:39am
I just talked to Minn Par and was told they have a lot of boots #048665 for my heavy duty rollers on my HD6e. I would think the same should be true for your needs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2018 at 5:29pm
I am still have 048666 spring assembly and have some 048665  boots for HD6
This page was generated in 0.119 seconds.
