Tow Bar
maddox_kid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote maddox_kid Quote  Post ReplyReply Direct Link To This Post Topic: Tow Bar
    Posted: 13 Mar 2018 at 6:12pm
I purchased a tow bar that I thought would mount to the rear of my 1954 B.  Unfortunately, I don't see a bolt pattern that fits on the rear of the tractor.  A picture of the tow bar is attached.  Any assistance would be greatly appreciated.
Would like to attach a cart or possibly a drag disc.uploads/7187/TowBar1.pdf
Post Options Post Options   Thanks (0) Thanks(0)   Quote maddox_kid Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 6:57pm
Sorry, I have a 1955 B vice 1954.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 7:08pm
Look at the final drive cases on each side..  There is a 3 inch diameter sheetmetal round cover over the end of the axle shaft.......... There should be two 5/8 hole in front of the round cover and two behind the round cover. .......... you can bolt it on there.. sometimes there is an adaptor plate / pin that  pokes thru one of the THREE holes and allows you to adjust up and down.
if its 12 inches too wide, then you have a "C" drawbar instead of a "B".
Edited by steve(ill) - 13 Mar 2018 at 7:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 7:10pm
Either that drawbar has had the ends modified or it is not for a B. The B drawbar is held to the finals by a flat piece of thick metal with a pin on one end and a bolt hole on the other. The pin goes through a single hole in the drawbar  and the bolt goes through one of 3 holes at the end of the drawbar which allows it ti be adjusted up or down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 7:17pm
Here is a picture of the basic B drawbar.
This one was listed in e-bay for $228, a bit pricey IMHO
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 7:20pm
and you need a vertical bar / rod up to the seat brace to support the drawbar in one position.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 12:43am
Your drawbar looks to be one of the earliest designs that Allis made for the B tractors. It should mount as the above posts say, however as your tractor is a 54 model, you will have to drill the smaller 1/2” holes to 5/8”, unless you would rather trade for the proper late model drawbar. Where in Md. are you located?
Edited by PaulB - 14 Mar 2018 at 12:44am
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 6:02am
Doesn't look like a B drawbar.
B is all forged from one piece.
The picture shows flat plates welded at the end.
Maybe for a Farmal Cub !
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote maddox_kid Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 11:35am
Thanks all for your replies.  I will see if I can make what I have work.  BTW, I live in Waldorf (Charles County) MD; but, from Maddox/Chaptico (St. Mary's County) MD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 6:20pm
MK, I'm halfway between you and Paul, If you want to trade, that's prolly the easiest way to go...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote maddox_kid Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2018 at 1:13pm
Went to view drawbar on a friend's AC B.  His has the plate with the pin.  Would like to trade my drawbar for one of that type.  Will be in the Bowie area Mon-Tue of this week if still interested.
BTW, anyone know of availability of a  "drag disc" for the B?
This page was generated in 0.375 seconds.
