Torque limiting extensions |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3253 |
Topic: Torque limiting extensionsPosted: 01 Sep 2021 at 1:42pm |
Anybody know how these work ? What happens when the torque limit is reached ? I've never seen any being used . Don't have a air gun myself , just curious . Thanks !
dee_veloper
Posted: 01 Sep 2021 at 2:50pm |
People also ask How do torque limiting extensions work? Torque sticks, also referred to as a “torque limiting extension bar,” are an extension for your impact wrench, and they basically act as a shock absorber. They work on a torsion theory, which is just a fancy way of saying they flex at a certain rate, then stop applying torque when they reach a specified flex point. Google is so handy..... |
Don't confuse my personality with my attitude.
My personality is who I am. My attitude depends on who you are. |
ACinSC
Posted: 01 Sep 2021 at 2:53pm |
Does that mean they just slip off ? Doesn't sound like a good idea to me , just wondering if anyone has used them ? Thanks !
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5191 |
Posted: 01 Sep 2021 at 3:37pm |
Most of the tire shops in our area have stopped using torque sticks and are now using a real torque wrench. When I asked the manager of the tire shop I use, he said they weren't as accurate as a real torque wrench.
I believe they slip when they reach the torque they are rated for. In other words, the drive end is still turning, but the nut end stops turning when it reaches the rated torque. Edited by WF owner - 01 Sep 2021 at 3:39pm |
Joined: 11 Sep 2009 Location: illinois Points: 90871 |
Posted: 01 Sep 2021 at 3:45pm |
They dont SLIP OFF... Just think of it as a heavy spring.. You can apply torque up to a certain level, after that the SPRING starts to move and you dont get any more torque.
ACinSC
Posted: 01 Sep 2021 at 4:08pm |
Ok , Thanks for the explanation . Makes sense .
thendrix
Joined: 04 Feb 2013 Location: Fairmount GA Points: 5182 |
Posted: 01 Sep 2021 at 6:39pm |
They twist when you get to the max torque rating
ACinSC
Posted: 01 Sep 2021 at 7:12pm |
Thanks Tyler !
JTOOL
Silver Level Access
Posted: 01 Sep 2021 at 7:46pm |
@ACinSC; Apologies if you know this already but an impact wrench works by applying the twisting force (torque) for an instant, stopping for an instant, and then reapplying the twisting force so many times per minute. The limiting extension will only twist so far with each application and twists (springs) back with the stopping, thereby only applying so much torque. That's how I understand it. I have a set, and they seem to work well when I've double checked them with my torque wrench.
ACinSC
Posted: 01 Sep 2021 at 8:01pm |
Thanks Josh . That's a good explanation .
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12422 |
Posted: 02 Sep 2021 at 7:02am |
If you have a tire shop that uses real torque wrenches and continues to do so, be sure and buy them doughnuts next time you go in. You can send me the bill and tell them "Bless you boys, these are on Tbone." I wish I had all of the tools I've broken getting tires off from ham-handed meat-headed morons that slam stuff on 'til the cows come home. If I did, I could set up a mechanic shop. And, stretched/ ruined lugs, cracked nuts. . . .arrrghhhh!!!!
![]() ![]() ![]() Edited by Tbone95 - 02 Sep 2021 at 7:02am |
ACinSC
Posted: 02 Sep 2021 at 7:37am |
Yeah Craig , that's why I usually take my wheels off 2 at a time and take them to the shop loose when I need tires . Thanks
Tbone95
Thanks(1)
Posted: 02 Sep 2021 at 8:54am |
Not a bad plan.
First thing I do when I get home loosen lugs, tighten with torque wrench. Beats breaking a wrench in the rain on the side of a freeway. |
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 02 Sep 2021 at 4:49pm |
I just recently almost had the left front fall off on my truck. So I'm following your advice Josh, I'm going to take em loose and torque em myself!
WF owner
Posted: 02 Sep 2021 at 6:36pm |
Reminds me of a story.... My nephew was going to diesel school in Ohio (Lima, I think). He had an old Mercedes that one of my daughters and her husband gave him. When he was home for a break, we put new brakes on the car just before he went back. The Mercedes had lug bolts, not lug nuts. I told him to make sure to retorque the wheels a couple times. He didn't. He called me and had lost the left front tire going about 80 mph about 5 hours from home (Buffalo area). I went and got him, we trailered the car home and finally got enough parts to get it back together. I am betting he will never forget to retorque wheels again !
