Torque limiter question?
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: Torque limiter question?
    Posted: 19 May 2017 at 12:18pm
A couple of pages back there was discussion about a torque limiter. why would a 4 pad hold better than a 6 pad disc, or does it?
Thanks, Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2017 at 12:31pm
More "squeeze" per pad. There's also different sized pads, which can change things a bit. In a normal foot clutch scenario, six pads probably will last longer than four, provided the operator keeps the free-play adjusted when wear occurs. In a torque limiter situation, the Belleville spring only applies "X" amount of pounds of squeeze, so it can slip if suddenly overloaded, unlike a coil spring pressure plate which can have more squeeze than is needed, once the load is started moving.  A torque limiter is designed to protect the driveline from shock overloads. A-C isn't the only company to use such a device.  Deere and Case do for sure and probably others I don't know about.
