180 hand clutch
180shane View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 180shane Quote  Post ReplyReply Direct Link To This Post Topic: 180 hand clutch
    Posted: 05 Jan 2015 at 9:59am
Just bought a 180 and was wondering if it has a hand clutch. I'm use to my dads 185 that has a t/a handle that you can put the tractor in neutral with. Tried it on mine but it doesn't go into neutral. Don't know if it's not working properly or it's not equipped with this option. TIA
sweany4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sweany4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2015 at 10:29am
my 180 hand clutch has a neutral position just like the 185.
200, 185T high, 180, rotobaler
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2015 at 10:39am
Shane - should be 2 levers on the right side of the dash.   Inside one is the Power Director (hand clutch) and the outside one is the throttle.   On the Power Director, forward is high side and rear is low side with neutral in the middle.   If you have checked in the last day or so with the cold weather neutral may be "dragging" due to cold hydraulic oil causing it to creep and seem like it's not in neutral.  Warm the tractor up and see if it still does it.   Check that your hydraulic compartment is full of the proper type of oil (trans/hydraulic fluid).   Left dipstick from the gear shift when sitting in the seat.   Report back after this and let us know as if you can't find neutral after it being warmed up others with more knowledge of what the problem might be can chime in.
Welcome to the Allis forum!   Where in Central MO are you?  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote 180shane Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2015 at 11:02am
Thanks guys will do. If it ever warms up here I'll try it out. If there is something wrong would it still stay in gear? It shifts to the high side just fine but when placed in neutral position it won't stop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2015 at 11:12am
Usually means a broken or warped pd clutch disc , or could be an o ring letting oil thru
Post Options Post Options   Thanks (0) Thanks(0)   Quote 180shane Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2015 at 1:28pm
Hey Mike, I'm located just south of Jeff City.
Edited by 180shane - 05 Jan 2015 at 2:05pm
This page was generated in 0.174 seconds.
