wd45 diesel wheelie bars
CTALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTALLIS Quote  Post ReplyReply Direct Link To This Post Topic: wd45 diesel wheelie bars
    Posted: 01 Jan 2015 at 3:47pm
 Looking for some ideas for building a new set of wheelie bars for my 45 diesel with 15.5-38 tires. I'm trying to leave the original lift assembly on the tractor. any pictures would be great..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2015 at 4:48pm
Consider raising the lift arms to the top and attaching a square tube with ears and pinning it to the lift arm end hole. This vertically hanging square tube would have the 5" x 5" skid pad welded to it. Now, add an angle iron to the square tube down near the skid pad and go forward to the side frame or axle housing. Generally, you want the enter of the skid pad 32 inches back from the center of the rear wheel (or more) and maximum of 9 inches off the ground. Good rules do not allow wheelie bars to be attached to the drawbar in any way.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2015 at 5:33pm
This is a bareback D17, WC,WD, WD45,all have similar attachment points
Hitch is separate.
Edited by Gary in da UP - 01 Jan 2015 at 5:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2015 at 6:18pm
And you trust two 1/2" bolts to support the weight of that tractor ?? Good rules also say the wheelie bars are to be strong enough to support the weight of the tractor when jacked up underneath the wheelie bars.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2015 at 8:01pm
Doc, these were built to comply with NATPA. They support the D17 @ 5500 easily. I don't play around building cheesey safety equipment. There are nine bolts , three in the center , three on each end.
I made them with a wide stance to make rear tire service easy, this is the simplist, sturdiest setup I could devise. What would you do differently ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2015 at 8:06pm
Your first picture was a waste of time. If they easily support the weight of the tractor, great. If they can't do that, how safe are they??
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2015 at 8:17pm
I really like mine. Bolts to the lift army holes. A cross link bar and a step.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2015 at 5:42pm
I will say Gary setup is good. I know him, he has pulled with our club, and I have seen that tractor up close
1968 D15D,1962 D19D
This page was generated in 0.344 seconds.
