Pin hitch drawbar for WD45 wanted
Horsepower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Horsepower Quote  Post ReplyReply Direct Link To This Post Topic: Pin hitch drawbar for WD45 wanted
    Posted: 24 Mar 2010 at 7:16am
Looking for a pin hitch drawbar for a WD45.  Does anyone have one for sale?
Thanks
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 7:26am
$45.00 very good. 785-353-2392
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 9:38pm
You looking for both pieces or just the front section?   Thanks...Dale
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2010 at 4:29am
Horsepower, You have a PM.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Horsepower Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2010 at 6:56am
I may be able to pick up a subsoiler that has a pin hitch.  Not too familiar with this set up on a WD45.  Can a snap coupler drawbar be used or modified to work with a pin hitch mounted subsoiler or do I need a pin hitch drawbar?
Thanks for the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2010 at 7:42am
No,you don't use the drawbar for the subsoiler. You would have to remove the Snap Coupler bell from you 45 to use a pin hitch set up.
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2010 at 10:53am
I believe some sub-soilers attached the factory drawbar (i think either one will work) instead of directly to the tractor
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2010 at 10:57am
If it is one that attaches to the drawbar, he still won't need a pin hitch drawbar. He could attach it to the snap couple drawbar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2010 at 11:01am
I believe you are right
Post Options Post Options   Thanks (0) Thanks(0)   Quote Horsepower Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 8:22am
Thanks everyone for the help
This page was generated in 0.081 seconds.
