hitch eye
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Topic: hitch eye
    Posted: 24 Mar 2010 at 4:44am
I`m needing a hitch eye for a plow or subsoiler. It is about 14" long and has (2) 5/8 bolts that holds it on the beam and the eye that goes into the bell under the tractor.
"Burgie"
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 5:57am
the hitch eye for a plow has a slight twist to compensate for the plow not being true with the tractor when using, I believe the subsoiler is straight
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 6:20am
I have some available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 6:23am
Chris, What do you want for them? zip is 47170
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 6:26am
Let me check them out this morning and get you some details, $10+ Flat Rate USPS S/H??, sound OK?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 6:28am
Sounds good. I`d like (2) of them. Send details. burgie@verizon.net
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 6:29am
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 6:46am
Sent e-mail. One of those e-mail address came back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 6:48am
The address is: burgie4@verizon.net
"Burgie"
