715b Backhoe..what is the year |
joe22
Topic: 715b Backhoe..what is the yearPosted: 27 Dec 2014 at 8:03pm |
Hi guys I have a 715b backhoe with a 2534 serial number but I don't know what year it is, so I can get the correct books on it .im having a problem with the injector pump leaking on the throttle rod any sugestions... I think there must be a o ring inside but don't know if it can be fixed without removing the pump. thanks for any help
Joe |
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4583 |
Posted: 28 Dec 2014 at 10:55am |
Your 715B is a 1979. The engine is a 236 Perkins. Parts are readily available for the engine from any Massey dealer. I've had a 1981 715B since 1987 and a 715 before that.
They are a very good realiable machine.
joe22
Posted: 28 Dec 2014 at 11:22am |
Thanks So much I have been searching hi and low im very grateful to you.I love it have had no problems except the leaking fuel. I have a parts catalog for a 1982 .... is the will this be the same for a 1979? thanks for all the help.it looks like just the o rings on the injector pump accelerator rod that are leaking wondering if there is a kit for just that or does the whole pump have to come of . thanks for the info Joe
joe22
Posted: 28 Dec 2014 at 11:25am |
Also I see you are from Canada and was what you do when starting it when its cold out, thanks
Calvin Schmidt
Posted: 28 Dec 2014 at 12:27pm |
To my knowledge there were no changes in the 715B's throughout their production so your 1982 book will be good. My 715B rests for the winter and has been a farm machine after years of digging silo foundations. The engine is getting very tired. The best way to start it in cold weather is to have a block heater. A LITTLE starting fluid is also very effective in these engines.
joe22
Posted: 28 Dec 2014 at 12:32pm |
thanks for all your insite thanks again Joe
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42274 |
Posted: 28 Dec 2014 at 12:51pm |
Plan on a can of starting spray for any time it is cold ,
If you can plug it in it helps also but many times mine was some where power wasn't handy
joe22
Posted: 03 Jan 2015 at 4:04pm |
Would anyone know what the weight would be for a 715b backhoe for transportation purposes thanks Joe
Calvin Schmidt
Posted: 04 Jan 2015 at 9:03am |
Sales literature does not list the weight but my guess is close to 12,000 lbs. |
Yooper Rod
Posted: 04 Jan 2015 at 11:45am |
According to the owners manual, the weight with the 7/8 loader, 24 inch backhoe bucket, and 11L-16 front and 16.9-24 rear tires, the shipping wt is listed as approximately 13,000. It appears that this is foe an open canopy.
