winter time thinking
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Topic: winter time thinking
    Posted: 19 Dec 2014 at 2:36pm
Just wondering what kinda power you would get out of a 301 GAS if ya bored it ta say 4 inch and strocked it ta say 5 inch in the xt they were Rated 77 hp draw dar just thinking out side the box
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2014 at 3:06pm
Why don't you bore to 4 1/2" and change connecting rods and stroke to 4 5/8" which makes 440 cubes.....been there...dun that. HP is mainly determined by carb throat size.
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2014 at 6:47pm
You will not make a 5 inch stroke fit in a 301 unless you use Briggs and Stratton connecting rods. Then it still might not fit.
Larry W. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry W. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2014 at 7:52pm
had one taken to 5.25 stroke with continental rods with angled caps,( was a project motor I finished that was started by Bob Sharpe), with billet rods like marties with a tighter angle cap would make it easier. things get really thin inside, and clearances where very tight at that stroke. 5" would be a lot better
Edited by Larry W. - 19 Dec 2014 at 8:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2014 at 8:50pm
I stand corrected. Shows you how much I don't know.
None the less, if 400ish cubes is the goal, I wouldn't bother stroking the crankshaft. The cost of the crank and billet (if you go that way)rods would not be cheap. If you have a bearing failure it will be expensive to fix. The head (with the gas head being better than the diesel flow wise - but still not good)will only flow so much and if the stock intake manifold has to be used the extra money spent for the last few inches would gain little performance and be better spent somewhere else.
If money and time aren't an issue and more than 400 C.I. is desired, then stroke away.
My personal opinion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry W. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2014 at 11:56am
I completely agree with you. the motor was a half done project someone else started, I felt it left a lot to be desired the way some things where done inside. if my memory is correct I think the rod journals where under 2" even. like you said, you can only pull so much through the intake anyway, and at low rpms it did ok. if I was starting from scratch it would have been shorter stroke, a larger bore then it was, and a fair amount more compression, it was a 8:1 settup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2014 at 4:21pm
The one I did, had Buda rods and even with those I had to grind flat spots on the camshaft to swing by. A nice set of custom offset rods would have been nice, but 4 5/8" stroke would be the max without welding on the crank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2014 at 6:39pm
Wow thats some good info now slip that in a d19 for 6mph 440 inches with lots of torque red guys look out
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry W. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2014 at 7:31pm
youre exactly right Dr. its like anything though, how much money,and how many billet parts do you want to throw at it.
This page was generated in 0.172 seconds.
