200 Rebuild? What do you think
dnel45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Topic: 200 Rebuild? What do you think
    Posted: 23 Mar 2010 at 8:00am
We have a 74 AC 200 with approximately 6,000 hours on it, doesn't seem to use any oil and runs strong still, but under load holds oil pressure right about 25-28 pounds, which I believe should be more like 40 pounds.  Recently the injectors started to leak a little oil and there are a few leaks out of the pan.  Is it time for a rebuild?  What should the oil pressure be under load?  Thanks
Don
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2010 at 7:27pm
Maybe just check your oil pump out and also your bearings. If the bearings are worn but the crank is in good shape then just roll in new bearings for now. If there are a lot of hours on the injectors then it might be a good idea to install rebuilt injectors.
Wink
I am a Russian Bot
This page was generated in 0.140 seconds.
