301 oil pump
mf440 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mf440 Quote  Post ReplyReply Direct Link To This Post Topic: 301 oil pump
    Posted: 15 Dec 2014 at 9:10pm
will a crank driven oil pump from a 426 fit a 301? I am looking for more volume
Big Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2014 at 9:42pm
For what reason do you need more volume?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2014 at 9:55pm
I've mounted a small 4 GPM gear pump where the hydraulic pump normally is located and used it for power steering using engine oil and returning it back thru a filter and to the left rear corner of the block for added GPM's (with a crank driven oil pump) on a twin-turbo engine for pulling. I believe the pump from a 7010 or 7020 is a little more GPM than a 200 engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mf440 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2014 at 10:25pm
I am running twin turbos and want to make sure i have enough oil to the system. have ran it a few years with stock crank driven oil pump and just want to make sure i dont have problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2014 at 6:17am
We ran the same little power steering pump with an old camshaft driven pump for several years with no issues. You have piston cooling jets drilled in the upper main brg saddles ?? Our main and rod bearings run multiple seasons with the set-up we have. Our top turbo is imited to 3 inch inlet, so HP is in the 1100 to 1200 range.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mf440 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2014 at 8:40pm
yes the engine has oil cooled pistons
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2014 at 8:29pm
Good question. I'm not sure what the GPM difference is between a 426 pump and a 301 pump. Then, if there is a difference will the 426 pump fit??
I would recommend tack welding the drive gear to the shaft no matter which crank driven pump you chose. There have been cases where the gear will slip / come loose from the shaft in a pulling engine. I suppose it's from pumping relatively cold engine oil at high engine speeds. Be sure the weld does not protrude past the end of the shaft or it will auger a hole in the front of the oil pan.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2014 at 8:57pm
a good practice anytime.... any engine.... after all these years had a failure like this on a 7020....
This page was generated in 0.219 seconds.
