how much engine do I need?
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: how much engine do I need?
    Posted: 14 Dec 2014 at 8:40pm
I have a wc I want to run in div.2, 3-4 mph class up to 4500lb class. I want to run 15.5 38s top cuts, how many cubes do I need to turn these in ohio clay?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2014 at 8:58pm
There is a huge difference between 3 MPH (low gear) and 4 MPH (second gear)....what do you currently have ??
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2014 at 9:14pm
I run 15.5-38 tires mine runs 4 mph in low gear
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2014 at 9:29pm
Most clubs run 3, one of them runs 4. Thing is, right now I have 14.9-28 @1600 rpm my wc runs 5mph in 1st, 9 in 2nd, 13 in 3rd and 20 road gear. This is using a gps cell phone that I have checked against car speedo and is correct. 38s are aprrox 15% bigger, so all those speeds go up 15%. I figure 1st should cover either speed limit. My tires measure 52 inches now. So in first how much to spin the 38s out at 4500lb.? I have been told by one guy 4 and 1/8 and offset grind the crank to 2 inch is in the 260 CI range and that is enough. I think he said use buda rods. What do you guys think, is that enough or just stroke it to 5 inch with allis rods? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2014 at 9:47pm
Something is waaaaay outta synch here. A WC low gear is 2 1/2 MPH at 1600 RPM....how does a 14.9 X 28 tire make it 5 MPH ???? and worse yet 20 MPH in 4th gear ?????
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2014 at 9:55pm
I don't know why so fast, 20 mph with hand brakes is scary. I wonder if the tac I am using is off. Maybe I running a lot more rpm than I think, I will check with another tac.
Zaddison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2014 at 11:49pm
May wc does 21 mph in road gear at 2100rpm. I've seen 5mph pullin a sled in first gear running 12.4/38s. So I'd say your running more rpms then 1600.
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2014 at 2:42pm
I used a wd45 crank with regular wd45 rods and a 170 engine kit including a Berry's cam as 170 carb. It gives out about 70 hp and 241 cubic inches I think. That is a lot of power for not a lot of money. That motor is bullet proof too, seeing how its almost a stock allis engine it should last me another 50 years, with loads of power for pulling. Just my 2 cent!
1950 B, 1952 pulling wd, and 1954 wd45
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2014 at 6:32pm
Whatever you do with pistons and connecting rods and crank stroke, you have to have correct compression when you get done. The last engine I built for myself was Buda rods with 4 1/8" pistons and to get the 12 to 1 compression I was seeking, I had to stroke the WD-45 crank to 5 3/8" stroke. You cannot just grab a set of pistons and sleeves and throw a set of different rods and crank together without a plan.....you might be really disappointed when you're done.
