need access to 620 right side brake
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: need access to 620 right side brake
    Posted: 13 Dec 2014 at 6:07pm
rear right wheel is locked from sitting for a couple decades. what's the quickest way to gain access to inspect the brake and what is the correct way to tear down to remove if necessary?
Thanks!
David
AcFordHawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2014 at 6:07pm
You will need to remove the drop housing and extension housing mounted to the transmission.
Page from the repair manual for illustration with the drop housing removed.
IB (restoring), MF GC1705, MF 2705E
This page was generated in 1.074 seconds.
