Deluxe seat for D-15
Gunn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gunn Quote  Post ReplyReply Direct Link To This Post Topic: Deluxe seat for D-15
    Posted: 22 Mar 2010 at 9:10pm
My current seat, the standard one, on my 1961 D-15 is completely trashed. I need a new seat spring, new pins and new bushings. The seat pan itself is the only thing decent. It's killing my back when I sit on it, as the seat leans to one side...
Anyway, before upgrading all of this, I was wondering if anyone could recommend, or has, a deluxe seat that was an option on the D-15? It's the black vinyl seat with a back and armrests. I'm not necessarily even looking for the exact OEM version, but maybe even one that's pretty close and will work nicely.
Otherwise, I'll start figuring out how to rebuild the one I have.
Thanks,
Tom
Dale Hardtke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Hardtke Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2010 at 9:17pm
I've never seen a D-15 seat With armrests ???
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2010 at 9:38pm
The only seat options on a D15 were the old tin pan style of seat, or one (see below) with the padded bottom and back - there were no arm rests.  Since your pan is in good shape, it is pretty easy to get replacement cushions - several vendors here have good quality ones.  If you have lots of time, your can rebuild your suspension.  I took the one on my D17 apart and had a local machinist make new pins and even put new bushings in the frame.  It is good for another 50 years now.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2010 at 11:35pm
I rebuild all of my seats with new bushings and pins.  Dave.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2010 at 11:38pm
I went to Tractor Supply Co. and bought a universal mount seat for my D17. It works great, I think it was about $80. It had the suspension and everything with it, it bolted roght on.
Gunn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gunn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2010 at 12:30pm
Sorry, my bad. What I was talking about was what was in the photo. A cushioned seat with seat back, in black vinyl.
I actually bought bushings to replace in my seat, and found the shock absorber at Steiner's.  But can't find the pins...? Does that seat in the photo sit atop the same basic suspension as my pan seat?
Thanks,
Tom
Edited by Gunn - 23 Mar 2010 at 12:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2010 at 4:09pm
I would think the pins would be the easy part.  I think it is 3/8" round stock, not exactly sure.  I got the seat off of my D17 series 4 right now as the pins, bushings, and the rubber bushings for the shock are all worn out.   That, the hyd. ram that is leaking, and the pto shaft that is leaking are my next projects as my generator just got dropped off to be repaired today so she won't be moving for awhile.
john n/il. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john n/il. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2010 at 7:11pm
It is 1/2'' round stock i just replaced all my rods in my 17iv.Im going to farm and fleet and see if they have 1/2'' round as now my brother liked how tight the seat is. now he wants me to do his 59-17 seat.Some of the old rods fought like hell to come out but with a little heat they came .
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2010 at 7:18pm
Does anyone know what size the bushings are?  I haven't taken mine apart yet.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2010 at 7:20pm
  we have ev erything tp rebuild your seat  cushions,bushings,shock etc.
   1-800-254-3116
Gunn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gunn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 7:44am
1/2" stock, sounds good. I figured I could make the pins if need be. I looked at my parts book and saw that they also used roll pins to hold the main pins in...I was wondering how they stayed in place.
 Now...is the suspension the same whether you have the standard or the optional padded seat? Might want to "upgrade" someday, and may be a better time now than investing in rebuilding what I have now.
Thanks all,
Tom
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 10:15am
the suspension is the same weather you have a pan or a padded seat.  I dont use the roll pins when I put it back together cause they rust in place and can be real tough to get out, I use a cotter key cause all it has to do is hold the pin for moveing in or out.  HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 11:15am
I also used 1/2 round stock for new rods and cotter pins instead of roll pins like Skip said.  I also had two of the bushing spots on the "dog bone" worn into the linkage.  I used steel full length bushings from McMaster-Carr, welded them in and tapped threads and put grease zerks in them.  Won't ever wear out like before.  Mike
Edited by Skyhighballoon(MO) - 24 Mar 2010 at 8:41pm
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Gunn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gunn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 7:44pm
Thanks again guys, fabulous information. I only wish I would have asked over the winter when the tractor was more or less idle.
That grease fitting is a great idea!
Tom
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 8:14pm
You can get the bronze bushings at your local hardware store. Same thing with the stock for the steel pins. You can buy a piece of steel rod and drill the holes for the small roll pins. I rebuild my shock, but now they have the reproductions like you got from Steiners. If the hole for the bushings are worn like above a little work with a wire welder and a grinding stone can have it back like new in short order.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 8:19pm
AN OLD GUNNY SACK WORKS GREAT ...
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
