716H with 919 snowblower
dnel45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Topic: 716H with 919 snowblower
    Posted: 10 Dec 2014 at 2:41pm
Will a snowblower from a 919 series fit on a 716H?  How about a front snow blade?  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2014 at 3:24pm
I don't see why not. I believe the frames are the same, and I think they utilize the same type of pto setup off the front of the crankshaft. Front snow blade should be the same also. Make sure you have an electric lift. I know that Dozer blade is one heavy dude! That would wear ya out having to pick that up emanuel. Same goes for the snow blower..
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2014 at 3:40pm
Here's the wife having a ball on our 716H with snow blade. Awesome machine!!
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2014 at 4:51pm
little tip if your manual lever operates the rear hitch at the same time like my 101 i hang a front wheel weight off a wd couter weights the snowthrower and makes it almost zero effert on the manual plus helps on traction.   by the way thats a sharp rig there
This page was generated in 0.138 seconds.
