Model D grader tires
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Topic: Model D grader tires
    Posted: 10 Dec 2014 at 2:06am
What size rear tires were most common on a Model D grader?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2014 at 4:50am
8.50X 20, I think...
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2014 at 6:04pm
I would say that the most common are 8.25-20" but some early models and most basic models did use 6.50-16" on the front and 7.50-20" on the back. They also used drop centre rims for the 6.50-16" and the 7.50-20" and flat base rims for the 7.50-20" and 8.25-20"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2014 at 7:32pm
Thank You for the info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2014 at 3:55am
9.5 X 20 military non directional tires will also work, if they are worn down about 2/3.  I bought a set from genesco, and you could fit a nickel between the 2 rears...
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2014 at 5:45am
Nathan, you might want to check with WW Tire in Watertown. Father-in-law bought 8 of those non-directional tires for his dump truck from them this fall. I think he said he gave $125 each unmounted. They are 8.50 x 20. They are new take offs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2014 at 12:01pm
I bought new "off shore" made cheap truck tires for my grader. Quality was not important as they would not be carrying any heavy loads at speed. They had three tread designs to choose from and being a little smaller in outside diameter than true grader tires or old military tires it left more room between the tandems for at least one set of chains. The military tread is almost useless in snow.
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2014 at 6:09pm
I called WW Tire today and no luck with the tires.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
