Were all D17 generators 12 volt?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: Were all D17 generators 12 volt?
    Posted: 22 Mar 2010 at 6:28pm
Was wondering if all generators that came on D17's 12 volt, or were any of the early ones 6 volt?  Trying to find a generator for my D17 series 4 and matching certain things up.  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2010 at 7:11pm
Chuckster,
Early gas versions were 6V. (Series I) Headlights mounted on the grill shell. A few of the Delco 12V versions used were the 1100305, 1100345, 1100440, rated @ 20 amps max. @2300 rpm, and the Delco 1100327, & 1100426 rated @ 25 amps @ 2710 rpm respectively... HTH
Steve@B&B
Don Jr NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Jr NY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2010 at 6:37am
I would respectfully disagree with Steve. All D-17 tractors came with 12 volt as standard equipment. I would guess that is because they increased the compression ratio and a 6 volt would have a hard time turning the motor over.   Don Jr.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2010 at 6:50am
I have a DR 1100994/5F6 single groove pulley 12v geny I do not need
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2010 at 6:49pm
I stand corrected. Don, you're correct! Wrong "D" series! I was thinking bout' the D14. My appologies Chuck! I shot you the wrong info....Gennie numbers are correct though...
Steve@B&B
