Steve NJ - voltage regulator
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Topic: Steve NJ - voltage regulator
    Posted: 22 Mar 2010 at 8:32am
Steve,
You asked for the model # off of the generator on our D17 so you could find the correct voltage regulator (Electrical Gremlins cont).  The model number of the generator is 1100305.  Can you get that in a negative ground type?  What do they run for price?
Thanks
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2010 at 4:57pm
Adam,
The 1100305, and the 1100345 are the same chassis unit. Both units are rated at a maximum of 20 amps and designed for P/Grd systems. I do have a few N/Grd 20 amp flush mount VR's that I could match to work with those two units in stock. VR would run ya $48. clams + the Postman. If yer' interested, need yer' zip to figure shipping....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2010 at 5:19pm
Steve,
It is: 62449
Thanks
Adam
This page was generated in 0.067 seconds.
