WANTED: Clamp-on dual hardware
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Topic: WANTED: Clamp-on dual hardware
    Posted: 21 Mar 2010 at 9:22pm
I just bought a set of duals yesterday at the local consignment auction and unfortunately they came without any hardware. I bought them for our 8030 which has 20.8-38 radials on non-power shift wheels. As a side note the duals are bias ply with about 25% tread and the main radials are about 75%, I hope it works out ok mixing types of tires. Anyway, for lack of a better term, I would call these duals a pipe-rail style. They are similar to a "T" rail only they have a pipe running around the inner circumference of the rim. Since there are 16 lugs mounting lugs on the tractor rims I was planning on using 8 dual clamps per side. What I am looking for then is a total of 16 clamps with, 3/4" threaded eyelets for the tractor rims and if possible 18" long hook rods. I am located in northeast Wisconsin and would prefer to pick-up if possible. Thank you for the help. Mike
Dale Hardtke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Hardtke Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2010 at 9:42pm
Michael:  I have Hardware to attach band duals, eyelets and clamping hook rods. I'm not sure  what a pipe-rail style is.  Dale @ (262) 719 3552  Watertown Wi.
