Points and condenser
steelhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelhead Quote  Post ReplyReply Direct Link To This Post Topic: Points and condenser
    Posted: 16 Nov 2014 at 3:41pm
I have an A/C B1 lawnmower with a B&S model 19D motor, I believe it is a 7.5hp. Im trying to set the points. The manual says to set the points to .020". I do not get any spark set at .020", I increased the gap to 0.20" and I get spark and the motor starts. The flywheel and keyway look ok. I set the magneto with a piece of card stock. I ordered a new set of B&S points(#298185) and condenser(#298060) to see if that would held. Im not sure what is causing this problem. Could the magneto be bad? Im not a mechanic so try to take it easy on me. Any help will be greatly appreciated!
Thanks, Craig
JRP1952 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JRP1952 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2014 at 3:47pm
I've also got a 'new' B-1 and am working on getting her running.  It's definitely a unique points/condenser set-up!
Got any pics?
-Jim
'38 B, 41 C, B-1, B-110, '80 Suzuki, and '94 GMC. Love steam trains, Space Shuttles, and "Allis Express"!
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2014 at 6:44pm
On a 19D the magneto is gapped differently than on the newer engines. It has a 3 leg coil which I believe is gapped at .020 instead of .010-.014. The points should still be gapped at .020 also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelhead Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2014 at 9:32am
I put in a set of new points and condenser yesterday, used all OEM parts. Set the points to .020" and put a new spark plug in and the old girl started right up. Big smile I guess she just needed a little TLC.
Thanks, Craig
This page was generated in 0.048 seconds.
