WD front V/S WC front wiight...
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Topic: WD front V/S WC front wiight...
    Posted: 14 Nov 2014 at 11:55am
I have saw it discussed, what is the weight difference in the wc front? looks to be hollowed out a little more, about two inches thinner? I need to loose at least 40#!
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2014 at 12:38pm
someone posted before about this. I think the WC was 50 or more lbs lighter
Charlie
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2014 at 8:00pm
My niece usually drives my WD45 in the 3500 lb. class, since I am very close on the weight.
I have a WC front end. It would be a lot easier to change front ends, than it would be to lose 50 lbs...
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2014 at 9:15pm
I am thinking around 50 or so
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2014 at 2:24pm
Maybe take off one wheel and hub? You only need one.
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2014 at 8:34am
try about 120
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2014 at 11:19am
Also rc wheels and 15" tires will lose about 20 pounds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2014 at 8:59pm
I always thought going from a tricycle WD45 to an old WC tricycle was about 100 lb loss. The WD45 is solid cast iron leaving just enough room for the steering gears and the WC is very hollow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2014 at 6:12am
Thanks out tp all.. I have done alot of searching, I see the unstyled front, it is considerably smaller. The WD45 IS thicker, I have one to compare to. The wd is some 3" thinner than the WD45, this WC I AM fooling with shapes just like the WD but is recessed back some 2.25 inches and "SOUNDS", lol! thinner???, when pecked on..
  I was going to do the swap to try and gain 50# off my puller, and still might. I put the WC in the shop yesterday after it sitting out in the rain for two days. It was unbelieveable! It was stored without gas in it drained carb, etc.... I put gas to it, a battery in it, sanded the points and it didnt much more than turn over and it was running! Super oil pressure, the lift worked like a charm, pto is smooth. I compleete tractor with straight tin, a great restoration project!!!! It run for about five min. and I began to see coolant, the block is busted......, LOL, on to be a puller now...
  I got to put a shifter pin in the tranny shifter, its just going everywhere.This will be my first... Heard horror stories about this.
bmartin55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmartin55 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2014 at 7:01pm
I have a wd & put a wc narow front under it I lost 75 pounds. .so I got in 3500 classes mine weighs 3200 now
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2014 at 8:07pm
Did you replace a WFE or NFE?
Tracker77d View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracker77d Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2015 at 7:11pm
maybe already on here but do i need a styled or flattop wc front to make my wd lighter
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmartin55 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2015 at 11:55pm
Unstyled wc front is light.,
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2015 at 6:41am
The one I replaced mine with came out of a styled WC. I could pick it up and walk with it. Im guessing 120# or so...
472bigblock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 472bigblock Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2015 at 1:16am
I have Massey fronts that bolt to frame rails a lot lighter than any Allis frt. easy to install and have the five bolt car wheel pattern so you can run alu. car wheels lose a bunch of wt. 937-368-2447
