WD engine compression |
den/southern illinoi
Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2080 |
Topic: WD engine compressionPosted: 20 Mar 2010 at 6:51pm |
What is the normal expected compression on a WD engine. If that is too hard to answer, what would the compression be on a standard rebuilt WD engine. Thanks, Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor. |
GregLawlerMinn
Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Posted: 20 Mar 2010 at 7:45pm |
The original 201 gas engine had a compression ratio of 5.75:1; that would result in approx 90 psi compression. However, after market rebuild kits that have higher compression ratio pistons have been around for a long time. 100-120 would be a tight one. If all cylinders are fairly equal in compression (within 5psi of each other), 80-100 should run smoothly.
