WC steel rear swap questions
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Topic: WC steel rear swap questions
    Posted: 20 Mar 2010 at 5:26pm
Are internal parts interchangable from a 1941 to a steel rear end?
Do I need to buy gaskets, make a gaskets or just use sealer for the final drives? and others to stop leaks? I know some are pricey. paper or cork?
I have to take some things apart anyway and have the steel rear to swap, so why not? I just do not want to be trapped with needing a specific internal part for steel only.
Can I keep my front unit/pinion assy. and just bolt on the steel rear housing?
Are WD45 and WC frame rails the same? I know there may be cultivator bracket holes in the front top.
thanks
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2010 at 5:30pm
 Some parts are specific to the stamped steel , check out the agco parts online.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2010 at 5:38pm
Larry, I would think the WD45 frame rails and the WC rails are different at least in bolt hole locations as the trannies are different and the flat part that was machined into the WD45 frame rails for the mounting points on the WD and WD45 trannies might not be there on the WC frame rails.  You might get away with using WD/WD45 frame rails on a WC, but not the other way around.  Just pointing out some things that I thought of.  I'm sure someone else will chime in on more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2010 at 5:43pm
I think my 45 rails are worse than the WC rails anyway! The 1954 rails are pitted and rusted worse than the 1941 !
Is the WC front pedestal lighter or quicker than the the 45? seems like both.
2014 HD Tri Glide
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2010 at 9:19pm
WC pedestal is lighter, and if I remember right is also a little faster. Kip
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2010 at 9:21pm
It sure feels that way, makes it a whole different tractor to drive, thanks
2014 HD Tri Glide
