301
graveyard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote graveyard Quote  Post ReplyReply Direct Link To This Post Topic: 301
    Posted: 31 Oct 2014 at 9:13pm
has anyone put a 301 into a d19?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2014 at 10:49pm
Not that I know of.  Several people have asked this before.  Basically, it is NOT easy.  Lots of changes need to be made.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2014 at 8:19am
We had one that pulled with us you have to make the frames longer hoods longer it takes work it is not a drop in personaly I want to put a 433 from a 6080 in one it will give you more power and lots better fuel as well as being able to add the front hydrolic pump for true live hydrolic if you are using it in the fields
Edited by bradley6874 - 01 Nov 2014 at 11:55am
nevans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nevans Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2014 at 11:44am
nephews are in the process of putting one in a D17 Niel
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2014 at 8:23am
BradinWA on here has a 301 in a D 17 and fits nice and pulls good!
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2014 at 9:01am
Have one sitting in the barn. 190 frame rails and a spacer i between the gas tank and hood.
Making a living farming with and working on Allis Equipment
Brad in WA View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad in WA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2014 at 2:16pm
I put a 301 in a D-17 using original sheet metal.Had to use D-15 radiator (shorter) and fabricate new front end. Also using an electric fan and water pump.Wouldn't be suitable for farm work, only pulling.
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2014 at 11:19am
I got one in a d17 with stock frames stock hoods and wheel base had to do a bunch of grinding on front axel.
BPM75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BPM75 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2014 at 1:01pm
I have an ongoing project that I've not had time to work on the last couple of years. Like most said it possible just not easy.
59 D17 gas nf, 66 XT 190, 69 220.
