D17 starter switch
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Topic: D17 starter switch
    Posted: 19 Mar 2010 at 12:44am
 While perusing some old service bulletines tonight, I ran across one that was for remediing the old key switch from stying in start position when starting the tractor. The nylon will get dirt in it and then won't release which allows the starter to keep running and over-speed. The "fix" was to put a push button switch in the cigerrette lighter hole that was in the dash.
  In all the years I never seen the early D17 have a push button switch in them, and I have seen othe modifications to the switches and dashes but not this 'fix'.
  I converted the 170 over to key switch start and always wondered why they didn't come from the factory that way except thought maybe for a safety reason.
 Just courious, ever see any push button starts on early D17?
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2010 at 5:59am
This was for the diesel tractors only. This bulliten is in the back of my D19 service manual
1968 D15D,1962 D19D
diamondc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote diamondc Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2010 at 8:43am
my d17 has a push button & it used to freeze up or get dirt in it.I just drilled hole out & put newer style push button. the old one had a rubber boot over it that was torn & it kept freezing in winter. it came from factory that way
