Off-color disc parts needed |
Keith inMN
Joined: 29 Oct 2009 Location: Central MN Points: 34 |
Topic: Off-color disc parts neededPosted: 18 Mar 2010 at 6:53pm |
I need a part for a JD disk or contact info for a salvage yard that might have the part.
I need a spool or spacer for the axle, where one of the hanger clamps mount.
The cast in part # is B13889B. It is 8 1/4" long. The large end is 4 1/2" outside diameter. The small end is 3 3/4" diameter. The middle is 2" diameter and about 3 5/8" between the flanges. The axle is 1 1/8" square but the spool I.D. is round.
Any help is appreciated.
Hopefully the pictures attach.
![]() ![]() ![]() Edited by Keith inMN - 18 Mar 2010 at 6:57pm |
Rawleigh
Joined: 14 Sep 2009 Location: White Stone, VA Points: 421 |
Posted: 19 Mar 2010 at 10:19am |
Keith inMN
Posted: 19 Mar 2010 at 5:25pm |
Thanks for the link. I searched their site and no luck. This model must not have been made for very long. Most salvage places don't have any parts and most aftermarket suppliers don't bother to make these parts. I'm hoping someone knows of a good salvage yard or knows of a disk parked in the weeds that can be cannibalized to keep another one functional. It looks like the easiest thing to look for is the length of 8 1/4 inches.
Tim in NC
Joined: 12 Sep 2009 Location: Hendersonville Points: 7 |
Posted: 19 Mar 2010 at 6:12pm |
Wow, $120.00 from mother Deere! |
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 19 Mar 2010 at 6:34pm |
Maybe you could buy a chunk of cast iron 4 1/2" OD by 8 1/2"" long and chuck it up in a lathe, make some chips and you'ld be in business.It would cost you more than $120 if you hired it done I'm sure.
Edited by CTuckerNWIL - 19 Mar 2010 at 6:35pm |
Darrell G (MN)
Joined: 11 Sep 2009 Location: Green Isle MN Points: 1496 |
Posted: 19 Mar 2010 at 7:08pm |
Keith there used to be a large boneyard south of Long Prairie that had a lot of old disc's out back, where in central MN are you located at?
Keith inMN
Posted: 21 Mar 2010 at 10:35am |
Darrell,
I'm located near New Prague. Do you have a phone number for the Long Prairie yard?
I've called Larsons/Cambridge, Hofland, Gotvold, Darwin and a couple others I can't remember at the moment. I must have a real odd duck with the 8 1/4" spacers. Everyone has loads of the 7 1/2" parts.
Thanks for any help.
Rawleigh
Posted: 22 Mar 2010 at 9:49am |
Just make it out of steel. |
Rawleigh
Did you try Shoup?
