Need starter for A/C 615
Art View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Art Quote  Post ReplyReply Direct Link To This Post Topic: Need starter for A/C 615
    Posted: 23 Oct 2014 at 10:11pm
My brother has a 1971 A/C 615 with the Perkins diesel. When he tried to start it this morning, got a lot of smoke and a few flames from the starter.
His rebuilder does not know if it can be repaired. We looked at several different sites, and can not find a replacement starter.
Any suggestions would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2014 at 7:08am
We can probably rebuild it. If its not rebuildable, I'm sure I could come up with a replacement. What brand Starter motor? Drop me a PM if interested...
Steve@B&B
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2014 at 9:03am
Are you sure that your machine isn't a 715 not a 615.  615 diesels were the 200 cu.in A-C engine and the 715 had the 236 Perkins. Should be a standard starter. I buy my Perkins related items from my local Massey Ferguson dealer.
Art View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Art Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2014 at 1:16pm
1. The numbers/name he gave is either a "Delco" which sends you to Lester 4512.
2. It might be a 715, as he could not fine the Perkins 'tag' on the block around the injector pump. It just might be a Allis engine.
Thanks for the quick replies. I'll make sure my brother reads all.
Art
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2014 at 8:35am
the 4512 sounds like the one for a 615 with the allis engine as I needed one for my 615    does the starter go in under the tank .   anyway you can find them but hold on to your hat, I looked for a month or better and found the only one in the country that didnt require a good core or a fortune for a core and still had to pay close to 300 bucks but it was rebuilt   most are in the 600 range as this starter was inly used in 4 applications and all had to be a diesel so not really all that many around
This page was generated in 0.250 seconds.
