Axle removal D 10 III
Joe/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe/NC Quote  Post ReplyReply Direct Link To This Post Topic: Axle removal D 10 III
    Posted: 17 Mar 2010 at 8:17pm
Trying to remove the axle from the housing. Shop manual leads me to believe, once you remove the snap ring a little tapping would drive it out.  I have heated and beat with a 5 pond hammer and it will not budge. Are the bearings pressed on and I need to get them pressed off and back, or just soak in solvent, heat and keep hitting?
Thanks,
Joe
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2010 at 5:36am
Call Me at 734-320-3470 i will walk you throught the process, David
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
This page was generated in 0.057 seconds.
