Rear Mounted NO.7 mower
WilliamNEOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WilliamNEOH Quote  Post ReplyReply Direct Link To This Post Topic: Rear Mounted NO.7 mower
    Posted: 17 Mar 2010 at 12:55pm
$350 for a working unit in the right ballpark? Guy said he will hook it up and let me see it run. Anything I should really look close at? Wanting to put it on my CA when completed.
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2010 at 1:18pm
If it looks to be  in good shape; and he hooks it up and it woks like it is supposed to -- then I would say yes $350 is in the ballpark. If you really want one bad and he is close to where you live, might be worth a little more.
Jason(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jason(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2010 at 8:08pm
Yes that is in the ball park. BE VERY SURE IT WORKS PROPERLY AND IS IN GOOD CONDITION! I bought one last winter that neede all new guards and the gear box rebuilt. I spent over $1000.00 in guards, bearings, seals, and other NOS parts that were missing or broken. Luckily I didn't pay much for it, just had a 5 hour drive, one way, to pick it up. I'm not trying to scare you away, just letting you know what you could get into if it is not in good condition
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2010 at 8:21pm
If it's not coming off of a CA you will need the mounting hardware for the balance spring that fits a CA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2010 at 7:38am
Like RMD says, the balance spring mount is different from WD to CA. The spring is the same. From the picture in the #7 book, it could be made fairly easily. I have used my #7 on my CA and never got around to making the balance spring mount and it works just fine without it. A #7 is a lot of weight to hang on the rear of a CA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WilliamNEOH Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2010 at 9:03am
Thanks for the input!
This page was generated in 0.406 seconds.
