wanted: tach for early D17 Diesel
bradu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradu Quote  Post ReplyReply Direct Link To This Post Topic: wanted: tach for early D17 Diesel
    Posted: 17 Mar 2010 at 12:01pm
I'm working on a D17 diesel that needs a new tach, but it looks like there are no aftermarket tachs for a diesel--only for gas.  Does anybody know where to find one for a diesel, or is there a way to make a D17 gas tach work on a diesel?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2010 at 4:51pm
The gas one will work, just won't be accurate due to the different rated engine speeds between gas and diesel. I have seen advertised in Oliver Heritage a place in Independence Mo called Metro speedometer that claims to be able to restore and calibrate tach's.
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2010 at 5:14pm
I think the gas and diesel tach's drive different directions one clockwise and the other counter clockwise.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2010 at 8:52pm
Yes, D-17 gas goes the wrong direction from a diesel.  Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradu Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2010 at 9:30pm
Well, I won't try that then.  I was able to order a new cable, but I guess I'll have to try some salvage yards or something for a diesel tach.  Thanks for the info!  Brad.
Henry se/k! View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Henry se/k! Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2010 at 9:35pm
The shop in Missouri does a real bang up job. Can redo yours or make diesel from gas. Have done several for me and look like new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2010 at 9:45pm
I had no idea the diesel turned the other way.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2010 at 10:04pm
  we can rebuild it  diesel turns oppisite gas have done several
  1-800-254-3116
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradu Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2010 at 6:43am
I'll probably check into that.  Hopefully I can get that dash hole filled w/o spending an arm and a leg.  Thanks a lot for the info.
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2010 at 8:17am
I have a tach. for D17D. MPH needle works,the hour meter does not work. It is original the face looks nice. $95.00  Thanks 785-353-2392
