426 exhaust manifold |
AC 7060
Topic: 426 exhaust manifoldPosted: 08 Oct 2014 at 8:54pm |
Has anyone used the exhaust manifold from crank machine for a 426 on a hotfarm tractor. Dr. Said use one off a in 414 which would be better. Thanks for the help. |
O.P.S. Heads
Posted: 08 Oct 2014 at 9:26pm |
What's "crank machine"?
AC 7060
Posted: 08 Oct 2014 at 9:56pm |
Crank machine service from New Baden IL they offer a new cast center feed exhaust manifold I think it is suppose to be similar to the D 21 na manifold
O.P.S. Heads
Posted: 08 Oct 2014 at 10:43pm |
as long as it is divided all the way to the turbo it will be better than any AC manifold.
AC 7060
Posted: 09 Oct 2014 at 8:10am |
Will the divided manifold help if the exhaust housing doesn't have a divider in it
O.P.S. Heads
Posted: 09 Oct 2014 at 8:34am |
Yes. It would work better with a divided exhaust housing, but the exhaust pulses are better used with a divided manifold from what I understand.
Edited by O.P.S. Heads - 09 Oct 2014 at 8:35am |
DrAllis
Posted: 09 Oct 2014 at 12:07pm |
The IH manifold has three advantages over the A-C manifold. #1. The exhaust flow only turns once coming out of the head (left or right) #2. the runners are a little smaller than the A-C keeping expansion from occurring until it hits the turbo #3. absolute pulse flow with built-in divider wall. The best IH manifold would be from a truck which would position the turbo down on the side instead of up under the hood. I haven't seen this after-market manifold, but doubt that is has more than the divider wall and flunks on #1 and #2.
cms
Joined: 29 Nov 2010 Location: collinsville il Points: 71 |
Posted: 04 Nov 2014 at 7:47am |
The IH manifolds don't have same bolt hole spacing and are not a true center dump.
DrAllis
Posted: 04 Nov 2014 at 5:33pm |
You have to make 1 inch thick spacers to adapt to the A-C head. Been there....dun that... it works better than ANY A-C exhaust manifold. The best would be the IH truck manifold.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5198 |
Posted: 04 Nov 2014 at 7:11pm |
The one Crank Machine Service is making is a much bigger, and better looking setup for pulling. It's just whether your rules would allow since it's not oem, and couldn't pass for oem either. The cms that posted is the builder. Dan Karpel, 618-401-2386 is on a card I have.
Peterson
Joined: 05 Mar 2011 Location: Westboro, Wi Points: 875 |
Posted: 04 Nov 2014 at 7:17pm |
Will the IH manifold clear the stock oil cooler pipe on the 426?
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
DrAllis
Posted: 04 Nov 2014 at 7:35pm |
I did it to a D-21 and had the oil cooler removed for the in-line injection pump, so I can't really answer your question with certainty.
cms
Posted: 07 Nov 2014 at 9:36am |
The manifold I have does fit with oil cooler on.
Peterson
Posted: 07 Nov 2014 at 9:38am |
Some pictures would be awesome!
Peterson
Posted: 12 Nov 2014 at 10:36am |
Seen some pics of the CMS manifold and I dont see a divider in the manifold. Im not saying that its bad but it really wouldnt be any better then the stock D21,210,220 manifold. Otherwise it looks nice.
One company I'd love to have build a manifold would be "Steed Speed" look up the manifold that they build for the 5.9Cummins Edited by peterson - 12 Nov 2014 at 11:04am |
cms
Posted: 12 Nov 2014 at 11:31am |
The pictures are the first one out. Have dividers in all manifolds have some with out.
Peterson
Posted: 12 Nov 2014 at 11:32am |
How much for one with divider?
