4-SALE
OUT#'RED View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OUT#'RED Quote  Post ReplyReply Direct Link To This Post Topic: 4-SALE
    Posted: 16 Mar 2010 at 10:48pm
I thought that I would start here first. I have started a new business and things are going better than I could of hoped for, Thanks God for mircles only problem is that I need some equipment to take on larger projects and that means a little house cleaning. I hate to get rid of anything(against my nature) but it is the right thing to do at this time. Besides it won't be worth much if I let it rust away and that goes against the reason for buying them to fix up in the first place.  So I am going to offer them up to you.
Wd 45 Diesel narrow front, runs but will need to be rebuilt I have all NEW PISTONS AND SLEEVES for it cost me $1048, extra oil pan, hood and gauge cluster $5000
D17 LP Runs great on gas, I was going to have the LP tank inspected before I had it filled haven't done that yet. straight tin good rims stays in all gears and good hi/lo good rims ok tires $2000
CA "NICE" painted with 2 bottom plow. Narrow front good tires and rims. $1800
(2) CA  both run but need to be fixed up and painted both narrow fronts $800 each
 D17 Diesel Runs good straight tin tires ok, good gears and hi/lo, wide front, used it to run my generator for 3 days when Ice storm hit worked great and fuel efficent. $2800
2 D-14 one wide front  starts and runs great hi/lo works good jumps out of third gear, rims and tires ok. One narrow front new head job with new valves last spring. works in all gears and hi/lo works good, tires and rims ok $1800 each
Wd45 and Wd both run, 3 parts tractors one wd-45, one wd, and one wc styled
 1952 Tractomotive runs good works good, runs in all 4 gear and shuttle works good, used it to pile snow this winter. good orginal rims I have orginal manual $2000
5-6 plows 4-2 bottoms all snap coupler $400-250
s/c disk $500
s/c 4 row planter boxes not rusted out w/extra boxes $500
s/c ripper straight shank $250
AC #7 side delivery rake $250
Wd#9 Loader frame is perfect no weld or bends, still has orginal J bolts, manure bucket is ok $400
Power steering for D-14 front bolster, hyd. pump, and lines $400
I am sure there is more. But my fingers HURT NOW!! I know what comes next. PICTURES!!!PICTURES!!!!PICTURES!!!!
Guys just was able to start posting again since I got a new computer (thank God for computer savy brothers) and have forgot how to post, second most of these tractor are stuck inside my machine and there is really no where to put them outside because what hasn't turned to mud STILL HAS SNOW PILED ON IT!! Or get a good picture in side. But I have some pictures and will get more please be patient, Third I am very busy if your a interested that is great but Please if you have No interest in buying anything please don't waste my time. I will leave my e-mail address on here and if interested contact me there. I check it daily but only after my days work is done and I have put together all of my bids that need to be summited.  I am located in central Iowa Email is spaulson@wildblue.net Thanks Guys (this has to be one of the best web sites ever)
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2010 at 5:36am
What series is the D-17 propane?
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2010 at 7:24am
That CA must look really bad if you painted it with a plow!! LOL!!!
I sure wish you were closer, I would buy one of those CA's.  Do the hand clutch work on them?  How soon do you need them gone?  I may be coming to Dubuque in the fall, Sep/Oct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OUT#'RED Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2010 at 2:15pm
serial # 21637 Thanks for asking
Post Options Post Options   Thanks (0) Thanks(0)   Quote OUT#'RED Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2010 at 2:17pm
John(mi) send me an email spaulson@wildblue.net I might be able to help you out. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote OUT#'RED Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2010 at 7:32pm
Rake, Disk, d-14 power steering all have been SOLD!!! THANKS
ALL SO FOR SALE
S/C 4 ROW CULTIVATOR $350
AC 226 POWER UNIT RUNS ON BOTH GAS AND LP RUNS GOOD $500
diamondc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote diamondc Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2010 at 8:52am
I could sure use the 226 power unit if it could be shipped to SW Saskatchewan,canada. email g.chichenko@live.ca. if we can make some kind of deal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OUT#'RED Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2010 at 8:05pm
S/C 4 ROW CULTIVATOR IS SOLD!!!! THANKS
ALSO HAVE 2 AND A HALF 33 PICKERS FOR SALE $350 FOR ALL
Post Options Post Options   Thanks (0) Thanks(0)   Quote OUT#'RED Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2010 at 7:57pm
diamondc having trouble sending up email contact me by email spaulson@wildblue.net Thanks Sean
This page was generated in 0.154 seconds.
