W rear ratios ?
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Topic: W rear ratios ?
    Posted: 16 Mar 2010 at 6:49pm
I tried to search and could not find what I wanted. What are ring and pinion ratios, WC, WD, WD45, WD45D, D17 and which ones can I put in a styled WC for(road gears)?
thanks,Larry
are their bigger step up gears?
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2010 at 8:20pm
the simpliest way to get speed out of it is to put it on 38 inch rubber like a high crop. it will run faster in road gear than most mens nerves can handle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2010 at 8:31pm
thanks,Larry
do not want 38"
2014 HD Tri Glide
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2010 at 11:06pm
Your only choice for WC gears are the standard ratio of 4.2:1 like you have or the SLOWER 6.6:1 gears out of a Hi-Crop WC or RC. What you might want to look for is a step-up M&W or Sherman auxilary transmission. Kip
