front end
hooken allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hooken allis Quote  Post ReplyReply Direct Link To This Post Topic: front end
    Posted: 02 Oct 2014 at 11:48pm
On a wd45 what is a better front end to use wide or narrow? I guess I'm asking what is lighter. I have herd some use a WC narrow.
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2014 at 8:11am
Early wc is #120 later wc wd ones #180 wd45 heavy narrow s #320 and a wide front is #350.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2014 at 3:09pm
Also depends on what weight class you want to be in. You can get a 45 under 4000 lbs. with a wide front but you probably won't be able to get under 3500 without going to a narrow front.
mgburchard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgburchard Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2014 at 2:29pm
A Massey Harris front end weighs 60 lbs
