Finished Project WD45
Juiceman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Juiceman Quote  Post ReplyReply Direct Link To This Post Topic: Finished Project WD45
    Posted: 02 Oct 2014 at 8:25pm
Some of you might remember from last December/January i was needing some help as far as building our WD45 for my senior project to pass high school. Well i never did get back on here and for the lack of better words "show it off." We had a lot of screw ups thats for sure, but learned a lot while we were doing it. Tractor was torn completely down to nothing. Everything separated. We had an empty rear end setting on blocks and that was it. Came from all the way down to back up to a complete machine in about three months. Marty Nelson sent us a 298ci short block assembly at first, then a head. We put a diesel ring and pinion in it for div2 pulling with our 38's. Dad and I got it running in time to present in May so i could graduate. We have had a lot of success this summer running 3.5 and 4mph. We hafta fix a pesky oil pan leak, which we have just gave up on for this summer, will address the issue this winter(Hints the gas can hanging from the bellhousing). This was in the 4000 5mph early this summer.
http://youtu.be/2vW5H0duHPs
Bryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryan Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2014 at 8:33pm
Thanks for posting. Runs very well!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Juiceman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2014 at 8:37pm
Thank you Bryan. I couldnt figure out how to get the video to show up in the message or it would have been a lot easier to view.
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2014 at 8:44pm
Great pull.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2014 at 8:48pm
I can't say if this helps or not. But I used a big block chevy oil pan stud kit on my wc engine. I did trim the rear cork seal. I does leak some. I figured from me trimming it. But if your taking the pan off anyway. You use all but a couple of the studs in the kit. Not bad for $20.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Juiceman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2014 at 8:52pm
I have another pull on video i'll have to post later i'm real proud of at 6000lbs 1st gear just working her guts out of the ole' girl. And how does the chevy studs help you? Im curious comsidering we haven't had much luck. Tried 4 times. Trimmed them once, but not the rest of the time. 2 of the 4 times we had the front and the back leaking. Lol
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2014 at 5:41am
That truck runs really well!
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2014 at 5:42am
6000 class
[TUBE]http://youtu.be/bL0b9hnKcEw[/TUBE]
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Juiceman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2014 at 9:59am
Thanks for finding that 6000lbs and posting. That was the night we figure just how heavy we can go, but it did probably as good as it could of i think. We had the balance pretty close atleast i think. Lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2014 at 10:43am
what are your rear wheels from?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Juiceman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2014 at 10:46am
They are just regular 16x38 9 bolt wheels. We have a set of 8 to 9 bolt adapters
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2014 at 1:59pm
That one just don't give up does it! SWEET!
Greg Kroeker
worldchamp19 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote worldchamp19 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2014 at 8:08pm
Nice pull! Did you do the engine work? Sounded good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Juiceman Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2014 at 9:43pm
We had to clearance the sleeves and block and assemble. Marty Nelson did all the machine work for us. We won 3 out of 4 classes tonight with it running 3.5 moh i'll hafta post a video later in the week. Had a lot of fun with it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2014 at 8:09am
Nice work on the tractor project. Congratulations on your wins!
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2014 at 6:21pm
Go Orange!!!!!!
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2014 at 5:33am
That looks good and sounds greatCool.  Nice job
As far as the pan leaking, watch Jim D's video of Don(MO) installing a pan gasket on a 226.  It will take care of your leak
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
