D17 hydraulic oil change question
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Topic: D17 hydraulic oil change question
    Posted: 15 Mar 2010 at 8:33pm
I have a question about a D17 III. When you change hydraulic oil is there just one plug to remove or two? My owners manual is for a series 1 and it shows the filler neck in a different location than mine. Is the power director fluid in the same compartment or is that separate?
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2010 at 6:38am
On a series 3, the compartments are combined and there are two drain plugs but one fill hole/dipstick to the left of the gearshift. Both plugs take a 1 1/8" wrench...one underneath the clutch pedal and the other on the bottom of the hydraulic pump sump. Refill with 22 quarts of hydraulic oil. These fill very slowly and then you'll have to start the engine and let it idle (maybe even with the front wheels downhill) for a few minutes before the oil can make it's way forward to the pump compartment. Change the filter also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2010 at 8:45pm
Thanks Doc.
