Movin' Snow with the WD 2/25/10
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Topic: Movin' Snow with the WD 2/25/10
    Posted: 15 Mar 2010 at 2:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 2:52pm
Don't mean to remind everybody about the big storm now that the greater part is gone,
but I just sorta figured out how to post a picture.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 3:17pm
Looks like it makes a nice pile!
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 3:41pm
We had over three feet of snow in two back to back storms on 2/24 and 2/25.
It was all very heavy wet snow.
To give some perspective; in the background to the right and just above my head is
my Dodge pickup and on the other side of it is my D-17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 3:42pm
Left, not right!
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 3:58pm
Brian,
It looks like your chains are nice and secure. How do you keep them on?
I plow with my WD and a bucket, but my chains keep coming loose. I even have them secured on both sides of the tires with bungee cords. Maybe it's because I have to plow on a steep slope and frequently spin the wheels.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 4:37pm
Goose,
I used to have a real nice set of good spring tighteners  on the outside of the wheels.
However, since I use my WD  in the woods for skidding logs, I kept tearing them off when I rubbed up against trees. I found that if I tighten the chains as tight as I can every time I see any slack, I have no problem. Believe me, I do a lot of work on side hills and I also do a lot of spinning. I believe that the cross chains have to be fairly long so that the side chains stay down on the sidewalls. Contrary to what a lot of guys have said, I have no problem with these "ladder" style truck chains slipping down between the bars.
I attribute that to the style of tire I have; with fairly angular tread.
These chains are fairly well worn and I break a cross chain now and then.
A couple of years ago a friend of mine gave me a brand new set of truck chains that were the right width but a little too short. I was able to lengthen them and find a few more new cross chains to make up a set to fit the WD.
I just can't seem to talk myself into using them as I might "get them dirty".  LOL
This page was generated in 0.065 seconds.
