Backhoe
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Topic: Backhoe
    Posted: 16 Sep 2014 at 12:11am
picked up a Mark V backhoe that is said to have come off a tractor. Trying to put it on a D17. Is there a mounting bracket specifically for a 17 or is this for a dozer? Any information would help. Thanks
AndyinWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyinWI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2014 at 12:29am
I have one on my d-17 industrial, it is tied to the loader brackets.
Andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2014 at 12:43am
I have a 615 AC backhoe attachment that was on my HD4 .  It was also used on other machines and tractors .
 It fit into a tool holder bracket on HD4 which had a U shaped slot on bottom and 2 pins at the top to secure unit to back of machine. Sp there was a stationary bracket the hoe slipped into and then coupler in hyd line with a diverter valve so hot valve body took full flow from pump, problem is it took bucket out of use so you had to set bucket then energise hoe.
This page was generated in 0.196 seconds.
