How to Adjust Brake Pedals HD9
BillRO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillRO Quote  Post ReplyReply Direct Link To This Post Topic: How to Adjust Brake Pedals HD9
    Posted: 10 Sep 2014 at 6:03pm
Please give me Advice on how to Adjust the Brake Pedals on a HD9, Thank you for your Help
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2014 at 10:41pm
Clean the rear case under fuel tank,shoud be a cover bolted on (been a long time don't remember how many bolts or size)slide cover back.The adjuster is right there,tighten until you cannot bottom out the pedal.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2014 at 5:10am
Like RAY54 said remove the small cover on the stering cluch compartiment cover under the fuel tank and turn the brake adjuster clockwise until the brake pedal has 1 3/4" to 2" free travel
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillRO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2014 at 5:56am
Smile Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillRO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2014 at 5:57am
Smile Thank you For Confirming RAY54 and giving More DETAILS
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2014 at 4:44pm
The dry clutch tractors also have a set scew up through the bottom of the housing which touches the bottom of the brake assembly. After adjustments, you take it up tight then back off I think one and a half turns. Its purpose is to prevent the top linings dragging on the drum when the pedals are back. Many of those have been thrown away leaving a hole for dust an mud to get into the housing
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillRO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2014 at 5:54pm
Thank you Mac
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillRO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2014 at 5:55pm
Thank you
This page was generated in 0.215 seconds.
