charging system help
johns10mm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johns10mm Quote  Post ReplyReply Direct Link To This Post Topic: charging system help
    Posted: 09 Sep 2014 at 7:52pm
Have an ac b-112 does not charge after tried cleaning contact points in regulator. I accidentally closed cut out contact and blew fuse. Can i test regulator and fix it thanks for any help Jeff
Edited by johns10mm - 09 Sep 2014 at 8:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2014 at 9:57am
Make sure that regulator is grounded correctly. Won't charge if it isn't. If the points aren't that good in the VR, you'd be better off renewing it. Should be good ta' go then...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote johns10mm Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2014 at 10:12pm
Thanks steve i finished cleaning contacts,cleaned all connections made sure base was grounded with meter. no its charging around 13.8 volts sometimes up to 14.3 just off idle
This page was generated in 0.707 seconds.
