wd radiator question
mrkurt35 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrkurt35 Quote  Post ReplyReply Direct Link To This Post Topic: wd radiator question
    Posted: 14 Mar 2010 at 2:59pm
i just replaced the hoses on my wd cus i thought they were leaking. filled it up with fluid started it up it dripped a little but when it started to get up to temp it started dripping alot . it looks like it is leaking out of the overflow tube. beginng to think it might be the cap is bad anythoughts?
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 3:13pm
Coolant from overflow tube can be a bad cap.  You can put it on a tester or just swap it out.
You may let it cool off and try again with the level a little to the low side to make sure it did not just trap some air and burp or just was overfilled.
Edited by Rick of HopeIN - 14 Mar 2010 at 5:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrkurt35 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 3:18pm
that would be my next step before i try and see if the radiator was bad itself
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrkurt35 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 3:41pm
i tell you what that bottom radiator hose was a pain in the butt to change
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 3:56pm
I'm with Rick on running the level down a little bit say about 1/2" down from the top.
When I change the hoses out I remove the hood and the two lower two 1/2" radiator mounting bolts and the back lower two 3/8" shell cover bolts, That will let the radiator move forward a little and the lower hose will go right on to the pump.
Don
Edited by Don(MO) - 14 Mar 2010 at 3:57pm
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 5:10pm
You need to leave room in radiator for expansion of the fluid as it heats up, if you don't leave enough room it goes out the over flow tube.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrkurt35 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 9:07pm
i have a repair manual that says it takes 3.5 gallons but only got 3 in. how much does it take?
John In. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John In. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 11:11pm
Mrkurt.   Put a catch can on for the overflow fluid, I wired one on by the dist. and run a overful hose into it, you will find that after you run your tractor for awhile the overful can will stay at the same level, once there then you have the right amount of fluid in your rad.     John
This page was generated in 0.172 seconds.
