Smokin Assets engine explosion
Jerald/KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerald/KS Quote  Post ReplyReply Direct Link To This Post Topic: Smokin Assets engine explosion
    Posted: 01 Sep 2014 at 9:31am
The Smokin Assets team had a misfortune of splitting our 2nd block at Louisburg Ks on Saturday night. Jason's wife Traci was driving this time after being out of for 2 seasons and was on a killer pass when it let go at 235 ft when it let go. Not much salvageable from engine. It even got the injection pump and all the aluminum sheet metal. Very thankful no one hurt. It even popped the grade 8 bolts on the external tie bolt system.
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2014 at 9:54am
To bad, hate to see people have problems, especially of that magnitude. On the bright side though it's nothing time and money won't fix.
What are they running for a powerplant?
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2014 at 9:56am
Too bad. Got any video from this year prior to the explosion?
sason View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sason Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2014 at 7:09am
its the 301 motor. punched out to around 340. 2 turbos feeding one. made 200lbs of boost right before it let go.
180 with a turbo and 460 loader.
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2014 at 7:35am
They always run the best just before they let go!!
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2014 at 9:06am
Thank God no one was hurt! One of these days, somone isn't going to be so lucky! And If you done this too two blocks, I would say your pass the limits of the little 301. Ouch
Brian-KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian-KS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2014 at 11:30am
I was there. It let go about 20 feet in front of me. It went "bang" big time with lots of fire....I would be willing to bet more than one of the fans around me filled their shorts when it let go!
EAT BEEF!
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2014 at 11:41am
I saw the videos on FB, and it was not a pretty thing to see. I have seen this tractor run, and it put down a pretty nice pass. What are your plans now Jere? I saw the gov housing was broken, but I'd be the pump can be rebuilt with a couple new housings for the governor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2014 at 4:06pm
200 lbs. of boost with two stages....wow!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerald/KS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2014 at 9:24pm
Yes, with todays custom billet chargers you can easily get intake pressure of 200-250 with a 2 stage 3 charger system. There are quite a few single charger diesel tractors making over 100lbs. As for farmtoybuilders assessment of exceeding the limits of the little 301 engine, unless you run an aftermarket block [JD & IHC], all blocks can and will split thru the cam area when boost exceeds 200 lbs. If you youtube you can find numerous videos of such explosions of JD and IHC. We made a policy to always run ours as hard as we can each and every time we hook to a sled. That is what a light super stock is all about.
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2014 at 10:04pm
What gear / final ratio do you run @ 6000 lbs?
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2014 at 10:34pm
The big question I have now. After taking off 2 years are they going to rebuild or what. And what can you do to fix the problem. And what is done to hold it together in the first place. Besides girtle, deck plate?
Post Options Post Options   Thanks (0) Thanks(0)   Quote sason Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2014 at 12:47pm
the driver hadnt been on a tractor for 2 years. we ran this tractor last year and got a late start this year. i have ran this tractor almost all of its life. final ration is around 19.1. we run a girdle. no deck plate but we had 1/2 grade 8 tie bolts that went through girdle to top of block and it broke all of those also. and ed on the pump yes gov housing was broke but we think it bent shaft where weights are.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2014 at 2:52pm
It's great that your using an AC tractor and engine and can afford this great sport.  And know your not only one splitting Blocks. Have been a few lately. Hope you can make it stronger and don't have a 3rd one explode!
