AC 720 Filters?
NC Bruce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NC Bruce Quote  Post ReplyReply Direct Link To This Post Topic: AC 720 Filters?
    Posted: 31 Aug 2014 at 10:34pm
After my mechanic worked on the AC 720 for about 8 weeks, we finally got it running and almost lifting an ARK 600 front-end loader, until another dry-rotted hyd. pipe ruptured! Among other things, we had replaced the starter-switch, rebuilt the starter, but couldn't get starter to even try turning. Finally wired in a relay switch to give continuous 12v to starter, and it worked!
1st) Does anyone have the Oil Filter types and numbers for the Onan 19.5hp? ( Car Quest ..... )
2nd) How about the types / numbers of Hydraulic Oil Filter? (NAPA....)?
3rd) My mechanic said to use 10W-40 multigrade oil in the AC 720 Onan Engine? I was always made to use straight 30 like Rotella T 30W (with zinc additive)? What do you say?
rtxdoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtxdoug Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2014 at 6:58am
FROM OWNERS MANUAL:  Engine Oil Filter Element AC number 2067272, suppliers should have cross reference. Hydraulic system oil filter 1650954. Engine Oil for above 90 degrees F use SAE 50, above 30 F use SAE 30, below 30 degrees F use 5W30. Nice tractor, I would like one. Doug in Ontario.
Toscani NE SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2014 at 7:57pm
I use only rotella 30wht in my 620 and 720 I use pure one filters on engine and hydro,i don't hav numbers off hand
OPRCzar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OPRCzar Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2014 at 8:11pm
Purolator Numbers
Oil filter  L20195
Hyd Filter L14670
The  Onan manual calls for these grades
Below 0 - SAE 5W30
Below 32 - SAE 5W30 or 10W40
Above 32 - SAE 30
Hope this helps
DON G View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DON G Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2014 at 8:35pm
Good to see you got it together Bruce.
Seems like I saw the loader before.
