Ok I did it, now I need to fix it! |
offdutyangler
Joined: 01 Jul 2014 Location: Madison WI Points: 88 |
Topic: Ok I did it, now I need to fix it!Posted: 22 Aug 2014 at 4:04pm |
First I will start by saying “I know now not to do this and
that I’m a dumba$$) Anyways, I pressure washed my A/C 712h (everything including
the engine) and now it’s starting really hard. I let it sit for three days and
still it’s really hard to start. What did I do? And What are some solutions for fixing it? (Prior to me washing it, it started really easy and I never
needed to use the choke.) |
1941 "WC" and a 1976 712h
dustydoo
Posted: 22 Aug 2014 at 4:40pm |
does it start at all or just crank over.I would check the air cleaner if wet wont start
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 23 Aug 2014 at 9:13am |
That's what I was thinking when I read your post. A wet n' watery air cleaner....
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 23 Aug 2014 at 12:48pm |
is it a kolher k301 12 hp if it is dry and clean and adjust the pionts i think .018 drain offthe fuel carb bowl
HudCo
Posted: 23 Aug 2014 at 3:37pm |
also remove spark plug wire out of coil and dry it
offdutyangler
Posted: 30 Aug 2014 at 8:07am |
Back to normal, thank guys.
